deacon
minor bike philosopher
Okay I'm not always too bright so I'm going to see if I can tap the collective brains of the group. I bought a generator specifically for biking. So I used it once to test a battery charger nothing exploded so I plan to use it. I also used it to operate a 6.5 amp electric lawn mower. Did i mention how I hate to try to work on gas lawnmowers these days. but I digress.
So the generator will run a 1.5 amp battery charger with enough amps available to run 3 more at least. So I'm wonderin, since I have a power supply on/off switch and can disconnect th3 batteries from the controller without removing it from the bike, would there be any harm in adding a second 1.6 battery charger in parallel to the battery pack. I am all wired up for it. Would the batteries charge twice as fast and require the generator to run half as long. Secondary question is would the batteries shut off each charger when they had a full load on.
Does anyone know or am I going to have to start up the old generator, with some extra batteries to test it out.
Thanks for any help.
