Q Matic warranty question to EZ Motorbike Co.
MotorBicycleRacing
Is the Q Matic warranty transferable to a second buyer?
The front 2" Congress pulley on my Q Matic serial # 500870
is worn because the V belt is running on the bottom of the pulley
and has also cut grooves in the pulley side walls from the top of
the belt.
Probably has ruined the belt too as the rear pulley looks worn in
the bottom of the V too.
What belt or belts is recommended for the Q Matic now?
Will post up pics later.
Thanks
Hi Neil [Forbisher/BiMoPed, etc],
Current Q-Matic drives can use a variety of belts. Version #7 has a slotted mounting plate to allow a wider choice of belt options. The current stock factory Q-Matic drive is equiped with either a 15260 or 15255 [depending on belt Mfg.] The Q-Matic for low RPM motors, such as the HF 79 CC 4 stroke, employ a AX25. Current drives also use the internal idler system [available as an upgrade from Authorized EZM Dealers]and all earlier Q-Matics can be upgraded.
If you can produce an original purchase invoice, be within a 1 year warranty, return any parts for inspection [you pay shipping] we will GLADLY repair or replace any parts found to be defective.
Have fun,
