prolong, mircolon ?
Hey guys just wanted to know if you guys have had any experience with prolong or micolon engine treatment I herd mixed reviews I just wanted to hear results from you guys my friend uses prolong and swear by it
I've heard it works pretty good... at least enough to be noticeable... don't do it until your engine is very well broken in tho because it may prevent the engine from breaking in properly and completely. We used to have that issue with high performance car engines when a customer would put the best synthetic oil in the engine right from the get go and the engine wouldn't break in because the oil was doing too good of a job. It's perfectly ok in my book to use a good quality dino oil the first 500 miles, or 10 hours of run time, then switch to the good stuff.
From what I've read, this stuff is supposed to bond to the metal at the molecular level in order to make the surfaces considerably more slippery, thus preventing wear and freeing up a little more power. According to Fred, he has claimed it works so good that a one way sprag clutch would slip after treated with this stuff, if that's true, then this would make a seat of the pants noticeable difference in these little engines and would be worth the effort, especially for wear protection and even more heat prevention.
One product sound like a Viagra knockoff and the other, some type of suppositorylaff
Couldn't help myself - honest!!!
Chris
AKA: BigBlue
I just ordered two can of E-Bay, little pricy but I don't care because I've gota boat load tied up in my FRED RACING ENGINES, 3 so far. I found 116 Octane @ $12 per gallon but that's only for when I'm out with my riding crew. the rest of the time I run 110 @ $7 mainly to the store and stuff.
HD ,which engine do you like best of yours the twin and guessing you have a very special single also ,
how close in hp are they to say against dave's reed 9.5hp race engines is this fair to ask you cheers
I have two "Tightcases" and a "STROKER" it's the badest and probably the closest to David Rust's 9.5HP. I don't know, however I'm gona call around and see if I can find a shop that can and will Dyno them if I can find the time. But thanks for asking.dance1
