I tried to reshape the barrel so the slide would fit. At first, I got the slide to fit a little better. But the more I screwed with it, the worse it got. Eventually, the slide would not fit at all. Luckily, I had the top half of the carburetor from a previous kit. I had tried to use that part of the carburetor before, and it had leaked badly. But I believe it was because I did something wrong. The old carb had a gasket on it and I didn't know it. So I was putting another gasket on, and I believe that was what caused the leak. However, today when I put it together, it was dripping fuel from underneath the valve, out from the bolt that holds the valve to the carb. I thought tightening that bolt would stop the dripping, so I took a socket wrench to it. Big mistake. The bolt never stopped, so I kept tightening, and the bolt sheared right in half. So now I have got a carb with no fuel valve. I'm hoping to locate the bolt, either in my garage or somewhere on this forum. I really don't want to spend $20 on a carb just for one little part.
