Please Help!!!!!!!!!!!!!!
kornbread
Well I Just Got My 80cc Raw Engine Kit Installed And I'm Having A Few Problems Will Anyone Help?
1)when I Turn The Gas On It Leaks Bad Out Of The Carb Any Suggestions?
2)when I Start My Bike Up It Only Stays Running For 30-45 Sec At A Time Any Ideas?
Korn,
Sounds maybe like your float is not doing its job. Remove the carburetor float bowl and see if the white plastic float has fuel in it. It should not. The float raises with the fuel level and by way of a needle valve should shut off the fuel flowing into the carb. If the float looks good then check the needle valve. It is above the small brass horse shoe shaped piece that the float rests against. Push gently up on that part, turn the fuel petcock on and see if fuel still flows. If it does there could be a small piece of trash stuck in the needle seat. Check these and get back to us. If the engine is flooded badly by excess fuel it won't run very well, if at all.
