mew905
Alright so I plan on squeezing out every ounce of performance outta my motor but I gotta know some things before I do it.
#1, the crank.
I screwed up my old crank by drilling out the wrong side. If I get a new one and balance it properly (or perhaps even re-drilling my 'ruined' one to make it lighter AND balanced), what can I use in the holes to preserve or boost compression if it's not a bolt-on style? Some old school tuners said they used epoxy and cork, Jag recommends aluminum. My concern is when I fill it I dont want it to come back out again as I've heard some horror stories (high speed scooters, actually, the counter-balance fillers slide out and catch the rod at high speed).
#2 the pipe
I plan on buying a new exhaust. Would it be worth it to learn to weld (I know 0 about it) and do a torque pipe, or is there good pipes available? Those of you who have used a gutted stock exhaust and moved to an expansion/torque pipe would have particularly valuable opinions here.
#3 The carb
I plan on buying a new carb. I have a Runtong (dellorto clone, also known as the Dax RT) and noticed the inherent disadvantages of only being able to tune the jet. You can jet for high end and lose all your torque, you can jet for low end and four stroke like crazy, or meet in the middle and notice it sucks at both.
Jag now sells adapters to run Mikuni 22mm carbs and I was considering going that route. Would it be worth it? I always suspected a huge handicap on these motors is the inability to breathe properly. I didn't notice much performance moving from the stock NT to the Runtong, just that it idles a little better.
#4 Heat/the ports
I plan on re-porting all the ports to ideal timing (I'll decide what that is later) and aside from making the intake bigger (I have reeds so I cant screw the timing up), I'll also be making the exhaust wider. Doing so will also increase the heat output of the motor, I plan on going to ~30mm (62% cylinder bore) and yes, I'll round and bevel the port. However with the extra heat output, would I be exceeding safety limits? Morini's apparently handle 375 to 425 head temps daily, as well as 1100 exhaust temps. My bike (I'll get accurate measurements when the time comes) reads 175F head and 230F exhaust. That's gotta be way below the threshold, so I'm curious, what temps are other members seeing? What would you consider as safe temps? (I know I asked this all day in chat but I keep ending up having to leave before an answer is given).When I ran the bike lean last year (for a few months!) I saw around 900F on the exhaust (glowing hot enough to see the ground under it at night), no damage ever occured from it.
Please answer any questions (or as many as you feel you'd have a valuable opinion on). I'd love to hear your replies. I'm looking to have a highway worthy bike. All hardware has been changed to high grade steel, all bearings are industrial SKF rated to 30k RPM and the head is a puch head so damage shouldnt occur there. And please dont go on about how highway speeds could be unsafe on a bicycle, I just want to see if it can be done with an HT.
#1, the crank.
#2 the pipe
#3 The carb
#4 Heat/the ports
