calschantz
Does anyone know what size jet is in the standard NTTC carb. I need to re-jet slightly smaller (it's 4 stroking) would like to know what the starting point is. Thanks for any help.
Could you post a photo of your carburetor? Several of us would like to see the NTTC designation. Thanks.Does anyone know what size jet is in the standard NTTC carb. I need to re-jet slightly smaller (it's 4 stroking) would like to know what the starting point is. Thanks for any help.
That's the way it's supposed to work. With the choke closed you are shutting off the air. Air is one of the three things your engine needs to run. If you close the choke, lever up, and the engine doesn't die then you need to start worrying.My issue, is I can only run and start my engine with the choke open... second I close it the engine shuts off.
