Ok, I've got an NT carb. there's a brass screw with spring sticking out the side of it. there's also an adjustment at the top of the carb where the throttle cable goes in. there's also an adjustment for the cable at the end of the metal tube where it goes into the throttle handle.
so, what exactly are all of these and how do I adjust them properly ? A buddy of mine says that the brass screw with the spring on it that sticks out of the side of the carb is the fuel air mixture screw. I told him he's wrong and it's the idle screw. I'm pretty sure I'm correct. Now, I understand the basics of how these carbs work. I used to restore british cars with SU carbs. The only fuel air adjustment that you can make is either to screw in a new jet, or move the clip at the top of the needle to another position.
I'm pretty sure I'm correct about that, but please enlighten me if I'm not.
Now, what is the cable adjustment at the top of the carb for and how should I adjust it ?
what about the cable adjustment at the throttle handle ?
anyone ? please help.
cheers
cheers
