Newbie here.....help!!
lwrussell
Hello all, I came into possession of (for free) what according to the data plate is a 2008 Pacemaker II, burgundy with gold trim. When I got it, I was told that it wasn't getting any spark, so first thing I did was check the plug and voila! Someone had put a brand new plug in that was too long and the piston had closed the gap on the plug. Put in a correct length plug and had fire. My problem is, I know nothing about these things. I keep hearing things like auto clutch and NE5, and I dont know what they mean. Mine has a little lever under the left control that I'm assuming is some type of clutch lever. Also, what is the starting procedure? I turned on both gas petcocks and put on the clutch and then gas was pouring out of the overflow tube...... How do I start this thing and what do I have? FYI it has 117 miles on it. How many miles can I expect? Someone, I don't remember where, referenced removing 'restrictors' to get more top speed. What's up with that?
Thnks!!:-||
Thnks!!:-||
Welcome, the little lever is your compression release. sounds like your carb needs cleaning. make sure you have clean gas, oil is SAE 40, 8 oz of it, be for you start it, then pedal like mad until she starts.
maybe you can post some pics so we can see what you got, if you still have the WC-1 cylinder or NE? 24" wheels or 26".
Thanks,
Ray
