Hi, This is an onging problem.  I had a previous post and thought the problem was mechanical but it wasn't.  My engine is slow to return to idle.  I have no leaks, mixture is not lean (rich if anything-plug is black), changed carburetor, took breather off slide works fine.  What I have discovered is the engine idles fast when I stop.  If I stop the engine and restart it, it idles fine.  Again when I run it at open throttle and stop again it idles fast.  Can't figure it out. It is something that is holding the throttle more open after running.  Head gasket maybe?  Checked head bolts not loose.  Thanks in advance,
i-paint
			i-paint
