Not even broken in yet, but won't run.
It's a LEB kit and is stock. Just mounted and run for about 4 miles. Shut if off and now it acts like it isn't getting fuel. I can push the primer button a few times and it will run for a few seconds, but then it just bogs to a halt.
Carb is stock and obviously very little use on it. I have checked to make sure the bowl is filling and moved the c clip down one notch which didn't help at all. I've played with the idle screw which didn't do anything. I've taken the carb apart and checked the jet. Blew through it just fine.
Checked for compression and tested the coil with a meter. It's fine too.
What am I missing?
What am I missing?
