worksuxxx
So this is my second build with a 29" Astra. The first build had a hoot, 29.29:1 drive ratio. With a couple pedals I was off and going. At times I would feel some shudder until the clutch engaged but was not bad. With the new build and 4g trans, I am running a drive ratio of 20.83:1. I have to pedal the **** out of it before the chatter goes away. It also clanks real loud until the clutch locks up. Also, with no load (wheel off ground), when the clutch engages it clanks very bad also for the brief moment it engages. It seems I have to be going really fast before this clutch locks up. I have checked clutch for burs, greased the bolts, installed washers and it has not helped. Sounds like a car with a rod knocking. The engine does shake violently under load until I get up to higher rpm. If I were to guess, I would think one pad is not releasing the same as the other two, causing the bell rotor to slam around. No sure where to go from here.
