need planetary gears for multi-speed trans
Proven trannys for use with peddle side drives. (engine->igh->rear sprocket)
Mount a cheap scooter motor above the rear tire with a 5 to 1 tranny.
http://www.niagaracycle.com/categories/torker-tristar-sturmey-archer-3-speed-coaster-brake-hub
http://www.niagaracycle.com/categories/torker-tri-star-3-speed-coaster-brake-hub
http://www.amazon.com/5-Speed-Coaster-Brake-Conversion-3-Wheeler/dp/B0063R1ZDU
Depending on the rear wheel size, mount a sprocket on the peddle side, or use a 12 inch rim with a bmx freewheel sprocket. Bonus for a bike frame that accepts a scooter rim.
Make a swingarm to hold an IGH so that you can adjust chain tension to the rear rim. Line up the output sprocket with the rear rime sprocket.
attachment.php
Line up the engine sprocket with the IGH input. Order different sprockets to get the right ratio.
attachment.php
If you must have peddles in your area, work on that aspect. Will the cops check for operational peddles and bump starting?
Speed v Rpm lines
attachment.php
Standup
attachment.php
Recumbent 42mph
attachment.php
