kelly dean
My OCC appears to have hung a ring i think. the cylinder is badly scored above the transfer port and scored badly and beginning a crack below the transfer port. the piston is badly scored in various places but mostly starting half way up the piston in the area of the intake port and the lower ring is broken. The engine is a triple 40 ZL40 rod it was running a OZ heavy coil and a gasbike supercharge cdi . speed carb and a stock muffler that i had cut approximately in half for ground clearance the cap was reattached but the inner baffle tube to the cap had been chopped. running 40 to 1, 87 octane and full synthetic oil about 5 weeks before this self destruct i had swapped the stock cylinder for a ported cylinder i used the original piston but replaced the rings .the ring pins were aligned toward the intake port. i ran one lower gasket the port timing at exhaust was fair about 3/16 of the piston peeking through at BDC i slightly filed the piston skirt to have a clear intake port at TDC. the initial start of the bike after the cylinder went well the bike pulled really strong running a 44t sprocket. i checked the plug after the initial start and short run it was lean and i adjusted the needle height raised one notch to richin and it looked good the right toast color. there was no indication that anything was amiss the bike ran really strong through out the entire range. it was running along good and then it just popped and lost abut half the compression and wouldnt start again .
im expecting a cylinder and piston kit mon 7th i have ordered a G4 cylinder and a G5 piston kit. I had a good quality new crankcase gaskit. this is my second adventure into cracking a case and be certain there is no debris lurking in there to ruin my day again
