my diamondback tanga
Len455
i put this engine on about a month ago, the bike is all double butted cromoly tubing. i ride this bike like a little dirt bike and it has no problem hauling my 125lb butt around. tell me what you guys think. the electrical isn't finished yet its getting a keyed ignition and im going to use some conduit for the wires. and shes a little dirty lol.
http://s1241.photobucket.com/profile/len455
len455
dnut
Today i spent2 hours going at the manifolds with the dremel and man was it worth it. Torque has doubled and i got and extra 3mph
Nice build, One thing you should do is, to secure the chain tensioner so it can not move into the wheel, can be a nasty accident
How do you secure it? I cant seem to find anything. Thx
This is one way, a screw that prevents the tensioner to go into the wheel
Be VERY carful if you screw through the frame ive seen a chain stay snap in two b/c it was drilled through! .duh.
Must clarify, it is not drilled in the frame, it is a set screw threaded into the tensioner. It's not a good solution if you are afraid of scratches on the frame
Otherwise, there are many good tensioners to buy from the different advertisers on the forum
or use the one that comes with the kit, and hope it works .duh.
i just used an old tire tube, cut it to length and put it on before the chain idler.
works well. i glued mine onto the frame and it doesnt seem to move at all once the bolts on the idler are hit with some loc- tite. worked for me.
