Morini
magrider
Up or sale is a Morini S6-S 9hp complete top end kit:
includes piston, rings, cylinder, head, reed cage, intake manifold, 19mm
PHBG Dellorto carb, misc. hardware, never mounted, never used. (missing wristpin needle bearing).
also included is a used Morini bottom end. with the top end removed, you will also get the removed head, cylinder, piston, rings, intake, side covers, flywheel, misc hardware, 14/16mm PHBG dellorto carb. (missing clutch cover gasket)
I will also throw in a used Morini 3-shoe clutch and washers flat and beveled, (some stock and SS) has 2 races on the clutch still many hours left. price drop $350
Just checked the parts and I don't have the needle bearing for the piston wristpin, don't know if I ever got it or it got lost in the shuffle, but everything else is there. Offers are always welcome as I am a motivated seller
The new:
more new parts:
the used parts, the bottom end has new Morini seals, bearings, and main gasket. no clutch cover gasket:
Hello Mag, if I buy this from you what is it missing to build a complete running S6-S? And is it hard to find that missing part?
Is it only the needle bearing that I have to complete?
