sportscarpat
I have a question for you Morini guys out there.  I don't have a motor yet, and am looking at the Morini dimension drawing I found on the Morini USA site.  This drawing gives a dimension from the center of the engine to the center of the drive sprocket of 55 mm.  Using a metric tape measure I measured the engine center line to sprocket centerline of a Grubee (China) two stroke and came up with about 35mm.  So that's 2.16" vrs. 1.37".  Are Morini engines mounted offset to the right in the frame so you can run a typical motorbike rear sprocket and idler?  I don't see how the Morini can be run on center with a standard 110mm rear frame dropout width.  What's everyone doing to make it fit?
