Micargi Mustang Build
IronHorseBikes
This build is nearly complete. The only real challenge I'm having is with the 4G clutch. Does anybody know of an upgrade that will replace the stock clutch that comes with this kit? It runs fine for the first few blocks and then seems to slip and gives a lot of vibration. Any input would be greatly appreciated.
Problem solved, if you are experiencing a lot of vibration at take off with the 4G clutch as I was this is most likely caused by a lack of lubrication that in turn caused the shoes to remain stuck open or engaged and they are not sliding back into position. (just as described in scotto's June 2010 post) Try removing the clutch and each of the pads, then grease the guide posts and springs behind each of the pads with a heavy engine grease. This completely eliminated the problem for me.
