Well, I finally decided to test out this "port matching" technique on a spare cylinder head I had from my very first motor.... I had to give up my base gasket to swap the heads so i have a leak now (oil dripping near cylinder base) however, the rev speeds are much higher, and I feel much better throttle response (after I tightened the idle screw a bit to compensate for the leak....) Anyways, I had a question, which is better to use as far as gaskets? aluminum or fabric?
PS, will definitely be port matching on all future motors!
