deacon
minor bike philosopher
The new wheel and motor arrived today too late to begin working on it. The 350 watt rhino drive motor came so I installed and tested it. I know that drive so well it was just a small project to swap out the motor and shorten the chain.
So tomorrow I fit the new rear wheel and figure out where to mount the motor. The seller sent me two pieces of chain that look an awful lot like bicycle chain. I think a bike chain would fit both the motor and the rear sprocket, but I'm going to use his at least for the motor. I think alligning the motor might be a trip, but since the chain is so heavy duty, I might get a tensioner if I need one. The motor mount has a tension adjuster if I can figure it all out.
The freewheel is on the rear wheel I got so I should be able to run the motor backwards. I might check out mounting it outside the bike frame It might fit on the axle but I doubt it. If all else fails I will just build a luggage rack over the rear wheel and mount it there. Tomorrow I will know more.
