mew905
So.... I cut my piston all to ****. but, it works, wonderfully I might add. Took off my intake before I took anything else off and noticed that at BDC my piston closes the intake. No need for that, the reeds will do that for me
So I pulled out my dremel and removed even more crap from the piston. Now I have 2 1/4" holes on each side of each wrist pin hole, one large reed window, and one smaller one closer to the rings. I'll let you know how it runs, in the mean time, have a look:
Weighs 97.3g, about 13g less than stock. they're heavy for a piston, but at this weight my bike is ridiculously smooth riding, smoother than most 70's-80's cars I've rode in. I'm looking to buy a titanium wrist pin (already found one) that'll reduce the weight a further 8.5g. Using the G circlips will reduce your weight an extra 0.1g (rather than the double ended ones), but I imagine using a real circlip will reduce it a bit more. Every little bit counts.
Once I get all that done, I may buy a new Minarelli piston (thinner rings, probably lighter weight and stronger), and if that meets my needs, I'll finally balance.
