intake pipe mod
breno
Pic explains alot.
Bored it out all the way through after pac welding around it. I pretty much bored out the existing pipe completely and am left with the weld I put there for the 1st half. Its 30mm long in total. Managed to almost get rid of the corner completely after pac welding it too. Its nice and tapered for the 1st half. I bored out the straight part too that goes into the carb by 0.9mm for the **** of it. All in all she sounds heaps tougher I can hear the intake almost as much as the exhaust.. lovin it. I had to keep abit of the bend in there so i could lift the carb a tad to keep it off the clutch bolt thingy. Paired up with the grubee exhaust its going fairly well. Looking forward to the 1st rebuid to balance the crank and wat not. And do any necessary cleaning/porting up.
Peace fellas
far out what a difference. Hadto move the clip to the bottom setting as it had started to run a little lean. The intake noise is gr8. Its easily picked up 5km/h and the pick up has improved dramatically too. .wee.
