Hey All,
I posted the below summary in my build thread, but don't think it will be seen as much as if I repost in a more appropriate spot, like here.
Note: This is a new build...and I'm new to these bikes...So thanks in advance for any suggestions!
(Repost from my last post on my build thread: http://motorbicycling.com/showthread.php?t=60258) This is a 66/80cc kit.
Been playing with the bike for a few days now...starts up great, idles great...but tuning it is still on the list as it's not perfect.
After about 40 miles on the bike (Still breaking it in), I wanted to check the spark plug. As I suspected, it's is oily/black. I know the mixture is heavy but also likely rich (16:1...moving to a higher rate for next tank). Before I messed with the carb any more (Needle clip at the leanest position) I wanted to play with a few things to see if/what will impact a leaner condition--Specifically with regard to exhaust and air intake.
With regard to air intake, I've run the bike without the stock filter to see how it breathed and it seemed to be a little better in terms of smoother idle and overall running. So I think the breathing of the carb could be better than the stock air filter...Not sure on what works best (More reading to do), but I see them advertised all over...so there seems to be some options there.
Anyone have a recommendation for a better air filter to fit the NT stock carb? I think SBP's has one that looks decent: http://www.sickbikeparts.com/catalo...ducts_id=99&osCsid=kva4ht4srbe2eh30u5lf6l9d87
As to exhaust, I am guessing this has the most impact for leaning out the bike. With the 16:1 ratio, it's pretty much dripping oil from the exhaust cap...so I took it off to clean...and for kicks ran it with the cap off... WAY louder! But also very very peppy! Lots of torque and ZERO 4 stroking! I'm sure this would impact top end speed, but I liked the power.
I think 2 strokes need back pressure, but how much? I think the baffles in there provided enough without the cap and still allow the motor to breath better (my only other 2 stroke was back in college and I didn't know anything about it other than mixing fuel/oil and riding it like an crazed idiot...so I never really played with tuning on one until now). I'd be happy to run it without the cap, but the noise level isn't really appropriate for anyone...so I recapped it and it fell back into it's mild sound and loss of torque , it's not ideal, but I'mm still breaking in the engine...so nothing is of HUGE importance right now. However, I want to figure out a way to open up the exhaust and minimize the sound down the road.
I've read up on a few ideas to drill out the baffles, but for some reason, all the posts on this are a few years older at least and I don't see anyone with the same type of exhaust (internals) as mine. When I unscrew the cap, all that comes out is the little exhaust pipe that's attached to the cap. Everything else (baffles, etc) are welded (I think) inside.
Is there a picture or two of the modern style exhaust internals anywhere?
Some ideas I had:
1) I could drill a hole or two in the little pipe (The one attached to the end cap that comes out when I unscrew the cap) I believe this pipe goes up into the baffles and pulls exhaust from within the baffle chambers.
2) I could cut the little tube off just inside the end cap...so that it no longer requires the gasses to be pulled from within the baffles
3) I could drill a hole in the baffle end-cap...this is the part of the internal baffle that's closest to the ground (Away from engine)...and is visible when the cap is removed and you look down into the exhaust pipe. This cap has a tube welded to it with lots of holes. (Not sure if drilling this cap will do all that much?)
4) I could drill the inner baffle end cap (I imagine this is closest to the engine side and isn't visible without removing the entire baffle assembly.) Maybe a combo of option #2 & 3 might work?
5) I could simply add another hole in the end cap?
Anyone have experience with any or all of these? Which would be the better route to go? (The good thing is these pipes are cheap and messing one up isn't the end of the world...but I'd like to do what's been proven to work as the first steps).
Thanks for the help/advise!
Some ideas I had:
