Latitude42
Ok, 1st thank you guys for all the useful info on this forum!!! This place is awesome!
My build idea is I have a Huffy 26" men's bike with 3-speed nexus hub/ coaster brake, beach bars, rear rack & originally had factory saddlebags. I have a 98cc 2-stroke 3hp Tecumseh engine off of a Toro snowblower I want to use in it.
I know I will have to get a different carb that is adjustable as the stock carp is single speed w/no air/mixture adjustments. I will need to make or find an intake because I will be changing the angle of the engine from it's original position on the blower to one that works with the "V" in the bike frame to get the new carb level so the float works correctly.
I have seen the "wizzer" style set-up where the engine goes back to a jackshaft, then to a LARGE rear wheel sheeve via a long V belt. The simplicity of a similar design is appealing. Put a centrifugal V-belt pulley clutch on the motor, skip the chain to pulley jack shaft and go straight back to the large sheeve on the rear wheel. Put a manual belt tensioner in somewhere to engage & disengage the drive. Maybe put a 12 volt generator as the tensioner to charge a battery. All the drive is on one side, simple and easy?
But, I've read that the Wizzer was ok (40mph) on flat roads, but a pig when hitting any incline..? Being my displacement is larger I'm not sure if my proposed set-up would have better performance. I would like to achieve 40 mph ash & be able to do some hills.
Idea #2...same clutch on motor to pulley on traditional jackshaft setup to my front sprocket to allow 3-speeds via rear hub. Install disk brake on front and rear & ditch coaster brake. Seems a more complex setup, but if it works would have it's advantages. Pulley and sprocket size would have to be figured out. I would like to keep belt pulley system on engine side to give a little buffer to the chain side and 3-speed rear hub.
Well, let me know what you think of these ideas please.
Thanks.
Thanks.
