islanddave
Hello All,
Just acquired a new Huseng engine. I filled the engine with 250ml of 10w30 and ran it. I then thought that I should look at and lubricate the gears in the transmission. as i was taking the housing bolt off a leak began to develop between the housing and the gasket. I thought that the gears and the clutch was dry and not run in oil. Am I mistaken? The housing also has an allen head bolt that is atop the outer housing. What is the purpose of this bolt?
Has anyone had success with running the gears and clutch in an oil bath? Perhaps motorcycle oil, as most bikes use a wet clutch system?
Thanks Dave
Thanks Dave
