Honda GS 190 How to use on Motorized Bicycle?
LabRat
This engine is on local craigs list $120. Add states it was removed from a pressure washer. How does one use this engine when end of the output shaft is geared? Is that part of the shaft or is it removable? See pic. Thx
Re: Honda GS 190 How to use on MB?
you need a gear puller and you use it to pull the gear and the shaft is under it its a good motor its 5.2 hp 8.3 ft lbs of torque and it weighs 31 lbs
forgot its counterclockwise and if you dont have a gear puller a machine shop will do it
This is what they can look like with some ( lotsa ) work in skilled hands. THis is actually a GC 160 but you get the idea. Pic 2 is what happens when you have a board machinest laying about...
Oh my lanta!
That is one freaking sweet motor! Their is a crisis in my pants haha
How long did it take to make the engine look like that?
I like the intake, sell any like that?
Is that bike Functional?
Not my build. Look at the videos, he rides it. Put some ice on that lump. It'll go down :)
always amazed at how skilled others are, its the kind of skill not forsale and when it is I can not afford it..... :(
You want a motor with the 3/4" keyed shaft so it take a common kart/minibike clutch. Don't buy a motor unless you know what shaft it has first. These are very common motors, you should be able to find one with correct shaft for under a hundred bucks.
Unless you know what is under that gear, don't plop down the coin.
