Many of us would still say you're a little oil heavy even at 20:1. You can safely reduce that to 24 or even 32:1.
You also need to consider that this is a new engine that is far from being broken-in. The piston rings haven't seated yet and you're going to experience some blow-by around them and the cylinder walls until you get some miles on the engine. We typically recommend 200 to 300 miles before we consider an engine to be broken in.
Break in procedures are as varied as the members here so don't ask what is the best way. It only starts arguments. Type 'break in procedures' into the search box and you'll have lots to read on the subject. You'll need to decide what works best for you.
I will ask what oil you're using. This too can be an inflammatory subject but it is something we'd like to know. Some oils work better than others but again, there are many opinions on this issue.
