Hi gang...new to this forum.
I know this has been covered here multiple times, but I cannot for the life of me get my '99 WC1 belts tightened. I've read every post I can find, I've jiggled the motor around after loosing almost every nut on the bike, I've pried the engine forward and still can't get the primary belt tight. I just put on a new AX27 belt and no matter how much I try to tighten it up, you can still push straight down on the middle of the belt and it will easily bend all the way down to the four posts that hold the side panel on. Also, when I do try to pry the engine foward, the front clutch pulley and the rear pulley just move together and nothing gets tight. Any help would be appreciated. I have the service manual, but it's almost useless in that it doesn't show you clearly which nuts etc. to loosen or identify them. Runs Ok on the flats but will slip quite a bit on a hill.
Also, I have tried to readjust the clutch cable after all my juggling around and it will not activate all the way when I pull in the lever...motor stalls out because it's not 'freewheeling'. Any help on this would also be appreciated!
Thanks in advance from a newbie...this forum is great. Already talking to Quenten re new cylinder head for the Wheezer.
