HELP im a beginner and cant keep bike running
cagle4cagle
Hey i just got a motorized bike kit from ebay and built it on my bike. When i try to start it it only runs for about 30 seconds if in lucky. The gas does not freely flow and does not fill the fuel line completely. I tip the bike back which fills the tube up but after punning it for 30 seconds the tube empties again and the bike dies.
Disconnect the fuel line from the carburetor and open the fuel petcock. You should get a steady stream of fuel flowing. If not then the petcock and or the in-tank filter is clogged. The kit supplied fuel tanks are notorious for containing rust and trash and should be cleaned prior to filling with fuel the first time.
We highly suggest to start with a 24:1 fuel/oil mix for break in then move down to a 32:1mixture after a few gallons. 16:1 is a bit oil rich and is just one of the fallacies you might see in the instructions that came with your kit.
i agree with 2 door...and i will add...ditch the stock fuel petcock and get the sick bike parts petcock it will save you trouble...but it doesnt have built in filter so you will need an inline filter.i had the same problem with my stock one it doesnt flow well.
