The problem with big bore carbs (over 16mm) is slow air speed though the venturi making for poor atomization of the fuel at lower RPM, This makes them hard to tune and gives poor fuel economy. They do work well at the redline at the expense of fuel consumption.
I can get over 80 miles range with the stock carb, it drops to nearly half of that with the 19mm Dellorto PHBG clone, depending on riding style. This is with a properly tuned carb, shaved head, port matched manifolds and opened up stock pipe, 66cc at sea level.
A 16mm throat size is the sweet spot for a stock 66cc
A 14mm would suit a stock 50cc
When selecting a carb make sure it is setup for a 2 stroke.
There are differences in the emulsion tube and slide cutaway.
A 16mm Dellorto SHA is a good choice for ease of setup or get the bigger PHBG if you have the time, tools and skills to set it up.
Run it lean once or twice and you will cook the engine.
The dellorto SHBC looks interesting, It looks like an updated SHA, anybody tried one?
