I was riding my motorized mountain bike recently one day when it suddenly seized solid and I almost lost control as I skidded to a stop.
The engine had been loosing power going uphill, but I thought it was a fuel problem as I discovered the fuel filter was clogged up with sludge.
I dismantled my engine and found the piston seized in the cylinder, the top piston ring was gone, the bottom piston ring was broken in half.
After removing the cylinder I discovered the needle bearing located at the top end of the piston rod was completely disintegrated.
Removing the piston, I found two deep scars in the side of the piston.
I then completely stripped the engine in order to clean out all the metal bits found throughout the engine itself.
I was going to rebuild the engine with new parts, but I damaged one of the engine shafts while taking it apart. Now I have to buy a new engine !
A new engine only costs $100.00 from the supplier my original kit purchase from.
