Giant build!
VenturiEffect
Just wanted you guys and gals show my build this is my first one. But im fairly mechanically inclined. What do ya think.
Good looking build! I have always been a fan of the SBP expansion chamber! Looks like your exhaust gasket might need replacing!
Lookin good! Nice to see lighting and a good helmet. (^)
The thing I noticed was the washer, spacer/ tensioners used for engine mounting. I believe you could eventually get those tightened down enough to be about permanent, but there are solutions mentioned on this site that are safer.
At the least, I'd carry the appropriate box wrench and tighten that front engine mount every few minutes to start. After a few miles, I'd check the nuts every few miles until satisfied that the engine vibration wasn't effecting the tension of the mount.
Safety first and all...
Let us know.
Surprisingly I didnt think the washers would work. But I tested it out I get absolutely no.vibration from the motor. Balanced crank and piston.. and the engine is on really tight. Works pretty well. And yeah im using the gasket from sbp aluminum. I put some coppper rtv and sealed it good gonna let it cure
Aldo every bolt imaginable beside the crank case screws are locked tite with the red kind. That stuff even fives pre stripped screws
Funny I mentioned your lights. I just put a headlight on the bike I'm riding now, and it saved me last night, at least from getting broken if not dead.
An hour after sunset- safety vest, no helmet. I saw him turning left, rushing to get through a gap in traffic. I figured it was gonna hurt good, hit full throttle and started pedalling. He hit his brakes enough to not hit me, and not get himself t-boned by traffic.
Super sketchy three seconds.
You've got em, be sure to turn em on! :)
