Installed on a Schwinn High Plains mtb. About 500 miles on the odo. Great fun but a few issues. First the flange on the clutch bushing broke within the first few miles. It still worked OK so I continued to use it. At about 400 miles I took the clutch bell off and the bushing came out in two pieces. To be fair, I only soaked the thing in oil for about an hour instead of overnight. I happened to have a couple bushings so I replaced the broken one. The new one doesn't have a flange. Seems to work fine with no drag.
The engine performance is good but not great. It seems to miss sometimes and act like it wants to stall. I've moved the choke lever slightly and it helps to clear it up.
And also, the engine has developed an oil leak. It keeps my chain well lubed but leaves a teaspoon or so on the floor overnight. I planned on installing a shift kit but now I'm leaning toward a 79cc Predator. I'm spoiled now and I don't want to pedal on the steeper hills.
Just a heads up for anyone considering a ghost racer 7g.
Does anyone know if the 7g transmission will work with the Predator engine?
