deacon
minor bike philosopher
here is the deal...
motor spins at 4500 rpm more or less
gear on the motor is 15 tooth'
I want to use the hub off a coaster brake wheel as the drive wheel. I think the diameter is about 2inches or so. I'm gonna add some jb weld and sand to make it a little thicker.
about the smallest sprocket I can get is 44 tooth.
top speed of 15mph is fine. torque is more important than speed. So what size sprocket should I put on the drive.
I know that on a 12 wheel the sprocket is good at about 65 teeth but it could run a bigger sprocket as well since it slips some when it goes up a big hill.
