when i say next to the motor, it's a girls bike frame so the petcock of the tank is almost parallel with the carb. The fuel line makes a kinda sine wave from the tank to the carb and the original petcock broke off so i had to replace i. The little built in filter i kinda rigged to stay on the new straight tap for the tank. So now i have a small piece of fuel hose connected to the tap on the tank, then a plastic fuel cutoff valve and about 6 to 8 inches of fuel hose to the carb. I took the fuel hose off the one side of the cutoff valve so i could check flow. Opened it up an fuel came out sorta steady but noticed small black pieces of something, don't know if it came from the tank or inside the fuel hose. So what should i do next, get new hose? get an inline filter? or maybe try to relocate the tank above the carb if possible?
