darkcobra94
I have a Hua Sheng f142 49cc engine, I used to use it on my bike before getting a 2 stroke. I recently decided to fix the engine up, i tried doing a bearing conversion for the one-way bearing, and I had to replace the entire crankshaft.
I replaced the crankshaft, used the permatex for the crankcase gasket. I installed the magneto coil and the pull start. I also cleaned out the carburetor.
Before I replaced the crankshaft, the engine ran fine.
Now, as I pull the pullstarter rope, gasoline seems to spew out of my carb. It does not start when I spray carb cleaner in it also. Compression seems fine, and the spark plug is making a spark. What could be causing the gas to be coming out?
