gas/oil soaked magneto
turbojoe
Well, my little Grubee decided to stop running the other day. Pulled the cover off the magneto and found it soaked with gas and oil. Will I be able to salvage this or will I have to replace it? I'm sure I'm sure I'll have to replace the crankshaft seal too. Is replacing the seal easy to do? Thanks in advance.
I should do a tutorial on this. It's been asked so many times before, but here goes.
First mark the magneto rotor (magnet) so you put it back on the same way. Remove the center nut and remove the rotor. This is where it gets sticky. There is a woodruff key that sometimes rocks and binds in the keyway making getting the rotor off hard. Ace Hardware sells a faucet handle puller that works perfect for removing the rotor. What you don't want to do is pry too hard on it with screwdrivers. The crankshaft is small in diamter at that point, about 5/16", and can be bent by unequal lateral force.
After the rotor is off, pick out the old seal with a seal pick or a small diameter tool. Clean the seal bore, lubricate the new seal and the shaft and drive the seal in to the bottom of the bore with a seal driver or a socket of the appropriate size.
Reinstall the rotor and coil and you're good. The coil might or might not be salvagable. It might be so oil soaked that it is shorted. New coils are available at most vendors who sell bike engines and parts. Good luck.
Thanks for that explanation. I got the magnet off and found small seepage from the seal.
Got the parts on order and really can't do anything till I get the parts. Again, thanks for the help.
