bluenosegoat
I've been figthting with this 49 cc kit from bgf for a little while now. I was in the process of taking the engine half's apart and when i took off the clutch cover there is no grease in it but gas and oil ! I imagine it muzt be the oil seal. Are there any trick to removing the seal and installing a new one? I've sent bgf an email about this- engine only has maybe 3 tanks run through. I must have gotten a bad engine. I was replaceing the leaking head gasket and decided to remove the cylinder and lap it down smooth. As i was pulling the cylinder off the bottom piston ring feel off in two pieces! As i was removing the piston I lost one of the "G" clips and thats why I'm taking the engine apart to make sure its not down in the crank case. I have to figure out a way to remove the magnet though as its being a real bugger!
On the bright side i got the sbp shift kit installed on my other bike! Way cool!
Any tips on the oil seal would be great!
