FVRITO MZ65 CLONE (read before you buy)
Wevil Kenevil
This expansion chamber clone of the mz65 is less than what you might expect.
First off the chamber is only 1/3 of what the mz is in size probably meaning that it only gives you 1/3 the power boost.
Second, the welds are shoddy and full of pin holes. It looks like a kindergartener welded it.
Third they welded the flange on crooked so it changed the way it sets on the motor so it doesn't fit right. And they made the bead around the pipe to flange so wide you can't get a bolt to sit flat against the flange.
Lastly it doesn't fit the ld100 with the billet high compression head.
Over all I give this pipe a zero rating. It's crap.
Mz65 pipes are only $10 more and are far superior than this or any other knock off.
I will post photos later.
