donb4103
I have never had this problem until today. A customer brought their bike to me to fix it. Well when you get it started it performs just right as long as you are riding with the engine pulling you. But as soon as you pull the clutch in the engine just takes off and will not idle. I have checked the cable 3 times and even replaced the carb with a new one and everything slides and works perfectly. The cable has no binding and seats perfectly every time. Could it be sucking air from somewhere and causing it to not want to idle? If I let it run like that for a few seconds it will finally start to idle down but it takes several seconds and the cable is all the way into the carb while it is running so fast.
