motorhedfred
I've been scouring this section of the forum to see if there's a pedal crank setup that I can use to drive my Sturmey Archer S2C kickshift 2 speed rear hub.
I'd like to drive through a 2 or 3 sprocket crank using the smallest sprocket for the pedals and the largest for the engine. Is there such a thing as being able to pedal independantly from the engine sprocket with them both on the crank ?
The rear hub has a coaster brake and is shifted by pedaling backwards like you do when braking on the coaster. Ideally, I want to use the pedals to shift ratios and have the engine use both ratios as well. Is this possible ?
I was thinking something like sportscarpat used on his Sportsman 200 prototype but with both sprockets on the same side. See post #76 in the thread below.
http://motorbicycling.com/showthread.php?t=33611&highlight=sportsman+200&page=8
MHF
Adendum.....maybe the rear crankset from a tandem bike ?
MHF
