paul
this is a trick i learned long ago to adjust you brakes. first screw the barrel on the lever all the way out. next with your hands hold the brakes tight to the rim. loosen the screw that holds the cable to the brakes and pull it tight and screw it down tight again. take the barrel on the lever and screw it all the way in and your breaks should be close to perfect if your tires are true.
