Drilling the jet
Toothy
181
San Diego
Hi guys,
I know this topic has been covered pretty well but I had a question. What are the symptoms of a jet sized that is too small? Do you loose power overall or is it in a particular range. I'm still 4 stroking in the lower RPMs and have reduced the jet significantly. Don't ask what size....as you know they are not consistent. It seems that it takes longer to warm up and run with the same power as before.
maniac57
Oct 8, 2011
4,484
22
memphis Tn
You should do a plug chop to check.
Here's a link: http://motorbicycling.com/showthread.php?t=42595&page=2
Best quick way to see if you are in the ballpark is to turn off the fuel petcock and keep riding until it runs out. If it runs better right before it stops, you might need a smaller jet.
If it seems to fall flat past 3/4 throttle and seems weak, chances are you're too lean already.
ALWAYS pull a plug chop after changing jetting.
Best thing to do is jet it for max power and running manners, then back off a size for reliability.
Running too lean can destroy a motor in a very short time so BE CAREFUL!
crassius
4,032
158
USA
if you get WOT to run right, then you often have to do a lot of trying diff settings on needle & float level until you get acceptable power thru the full range (sometimes requiring a redo of the main again)
