Hello. Newb here. The bicycle I am looking to build is a folding model. The frame design requires the engine to be mounted behind the rider...thus a typical jackshaft kit that is designed to be mounted to a normal engine assembly itself may not work. I will be using the frame around the back wheel as well as the rear rack mounts to install the engine mount plate. Then I want to run the chain to a jackshaft from there. The problem is I cannot find any jackshaft kits specifically designed to be "stand-alone". They all seem to integrate the bicycle engine assembly. There is a spot on the bike where I can put the jackshaft which has 3 solid areas that I can use for mounting points...so I was hoping to use strictly the frame (not the engine like normal bike engine kits) for mounting the jackshaft. Does anyone know of any "stand-alone" jackshaft kits? Or am I fabbing up one of my own? Or altering an existing kit?
Ideas?
Thanks in Advance!!!
Ideas?
