Toadmund
CYLINDER diameter 4.7cm
after the taper at the top of cylinder the gasket mating surface is 4.9cm diameter.
HEAD gasket squishband surface 5.25 OD, 4.1 ID
Here I will concern us all with the OD of the head which is 5.25cm and subtract that from the cylinder mating surface of 4.9cm
5.25cm - 4.9cm =0.35cm
result:
I have a gasket mating surface of 1.75mm (note mm not cm) around the circumference.
What the ****, is that right, a mating surface of less than 2mm?!
I feel compelled to mill the head band right off and make a thicker gasket(s) that will seal all around tight around the bolt holes and the whole surface.
I just realised this morning that I have a bunch of aluminum flashing left over from a door replacement I did, that could make gaskets.
result:
