DAX Gearbox Front Sprocket
Bayouself69
Now that I finished my first build.I am looking for improvement to my next one.I have a Felt wide rim front and rear wheel.I have a Manic Mechanic rear hub adaptor.I would like to know if any one make a front sprocket to fit a Dax gearbox,running 41 or 415 chain.Dax uses a 8mm chain.laff
The 8 mm chain is inside the gearbox the drive sprocket is for 415 chain
My bad, mine takes 415 chain same box, look up graingers for sprockets
In Frame 4 Stroke Gear Box Package Deal.
Includes Gear Box 3:1, 14T , 72T Rear, 62
in 102 Link 8mm racing chain, Sprocket
mounting hardware. Everything needed
to convert your 4 stroke in Frame over to
Racing 8mm setup !! Fantastic !! 1 Year
Warranty. Only $99.00
The front gearbox sprocket 14 T and the rear sprocket 72 T is also 8mm chain
this is the kit I just purchased from DAX The front sprocket is splined inside not just a key way,it is held inplace by a snap ring.This is why I am looking for a sprocket upgrade to 41 or 415 chain
.Yes the inside of the gear box is also 8mm chain
