a bad gasket between the cylinder and case causing an air leak would cause an overly rich condition correct? My engine was running super rich, wouldn't run unless it was half choked so I pulled the plug and it was fouled to the point I can't believe it ran. Intake and carb are both tight. I spun it over with the plug out to blow out excess crap then restarted and it ran but same thing, won't run unless half choked. Cylinder gasket is one I made myself .
