I was rebuilding my engine today and i was tightening the nut which holds magnet in place. and as i tighten it harder the the whole crankshaft will start to rotate, so i have put screwdriver between the gears on the other side(clutch gear and engine gear) so i can thighten harder.
and as i tighten the nut harder it kept spinning and spinning
and i checked the other side and the screwdriver is still there and holding the gears from turning so i was what the **** is going on?
and i found out that the crank shaft on the magnet side is spinning off the crank.
and i was like what the **** ? should it do that???
i don't think the other side crank would spin like that then the whole engine won't run, lucky it is magnet side... though i'm scared that it will happen like that for the other side too and the motor will be just spinning by itself and won't pull anything.
I don't know really...
if the magnet side crankshaft should spin freely like that...
it's still kind of tight so only way you can spin it is with the nut and the wrench...
but i'm kind of worry that it will get loose and won't spinn the magnet either
i understand the magnet is light so they might not have put no key way to hold the shaft with crank, but i think they should've put key way anyway
what do you think???
by the way has someone disassembled the crank?
