Greetings all,
I'm new to posting to this site but have been researching my problem and have run out of ideas..
So I was riding to a Bacon Festival yesterday morning when mid ride I lost forward power.
This is a 2 stroke new build with a c-clutch with about 100 miles total. I was passing a family on the path so I pulled the clutch and killed the engine so as to not startle the little ones. When passed them I went to pedal start the motor and released the clutch but nothing happened. I pulled to the side, took off both covers and didn't see anything overtly wrong so I pedaled back home sans bacon.
Here's what I did:
I checked the clutch cable and activator and that is working normally.
I took off the front chain gear and checked to see if the woodruff key had somehow come out or sheared and it was still in place and looked fine.
Then I took off the c-clutch and checked the gearing and didn't see anything either. I cleaned the clutch pads on both in and outer assemblies in case they were just coated in oil and wouldn't grab but afterwards its the same result.
The bike rolls with and without the clutch engaged but the clutch engages the large and small gear on the R side under the clutch plate when the handle is released but it seems like there is a disconnect from the motor to the drive system..
Do I need to split the case to look deeper? Any ideas of what I should be looking for?
Any help would be greatly appreciated!
Here's what I did:
