Clutch Arm
tomahawk
Clutch arm keeps popping out of the hole in the side cover...whats up with that? How do i keep it from popping out?
There should be a pin that holds it in place so that it will only come out when turned a certain way. Look inside and just above where the bucking bar goes into the cover there should be a small hole, see if either the pin fell out or has broken off.
Thanks for replying. I did find that the factory neglected to put a pin in there so i made one out of a cotter pin and forced it into place....seems to work.
